Documentation for Users  2.0.0
Perception Toolbox for Virtual Reality (PTVR) Manual
End current scene
Default behavior
The EndCurrentScene Callback ends a scene and goes by default to the next scene of the experiment.
my_callback = PTVR.Data.Callback.EndCurrentScene ()
# default behaviour is to go to the next scene
This default behaviour of going to the next scene can be changed by further calling SetNextScene () (a method / function of the 'EndCurrentScene' Callback) with an argument defining the scene that must be presented next (called ID_of_the_scene_to_be_presented_next in the code below).
my_callback.SetNextScene ( idNextScene = ID_of_the_scene_to_be_presented_next)
Examble of use
This code is often used to create a cyclic presentation across time of all the scenes created at the beginning of the script. For this purpose, the variable ID_of_the_scene_to_be_presented_next is the rank of the first scene of the set of scenes.
Demos
Python file
Description
...\PTVR_Researchers\Python_Scripts\Demos\Scenes\ 2.0_one_scene_w_NON_simplified_duration.py
Creates ONE scene whose duration is controlled by using a standard interaction between an Event and a Callback.
...\PTVR_Researchers\Python_Scripts\Demos\Scenes\ 4_cycle_of_scenes_w_NON_simplified_duration.py
Creates a CYCLE of scenes whose duration is controlled by using a standard interaction between an Event and a Callback.
